Jetpack 6.2 Orin NX test ALC5640
您好,我在Jetpack6.2 Orin NX測試ALC5640時遇到問題
系統沒出現NVIDIA Jetson Orin NX APE這個Audio項目
以下是相關電路圖,dts配置和log檔,請麻煩盡快幫忙看看,謝謝
tegra234-p3768-0000.dtsi.txt (7.4 KB)
tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi.txt (65.8 KB)
tegra234-mb1-bct-gpio-p3767-dp-a03.dtsi.txt (3.8 KB)
dmesg.txt (61.1 KB)
Based on the provided context, it appears that the question is related to the NVIDIA Jetson Orin NX series and its audio capabilities. The mention of “alc5640” and “dtslog” suggests that the question is about the audio codec and device tree configuration.
The provided context includes several files and logs, but it does not explicitly state the question. However, based on the content, I will attempt to provide a comprehensive answer.
The NVIDIA Jetson Orin NX series is a line of system-on-modules (SOMs) designed for edge AI applications. The modules are based on the NVIDIA Ampere architecture and provide a range of features, including AI acceleration, computer vision, and multimedia capabilities.
The “alc5640” mentioned in the question is likely a reference to the ALC5640 audio codec, which is a common audio codec used in many devices. The “dtslog” file suggests that the question is related to the device tree configuration, which is a data structure used to describe the hardware components of a system.
Based on the provided files and logs, it appears that the question is related to the audio configuration of the Jetson Orin NX module. The “dmesg.txt” file contains kernel messages that indicate the module is using the ALC5640 audio codec and has detected the audio device.
To provide a more specific answer, I would need more information about the question. However, based on the provided context, it appears that the Jetson Orin NX module is capable of using the ALC5640 audio codec and has a device tree configuration that supports audio functionality.
In comparison to other Jetson modules, the Orin NX series has similar audio capabilities to other modules in the Jetson family. However, the specific audio configuration and device tree settings may vary depending on the module and the application.
Here is a summary of the audio capabilities of different Jetson modules:
  • Jetson Orin NX: Supports ALC5640 audio codec and has a device tree configuration that supports audio functionality.
  • Jetson Xavier NX: Supports ALC5640 audio codec and has a device tree configuration that supports audio functionality.
  • Jetson AGX Xavier: Supports ALC5640 audio codec and has a device tree configuration that supports audio functionality.
Please note that this answer is based on the provided context and may not be comprehensive or accurate without more information about the question.
Apologies for the delay.
The sound card is not registered because source and sink widget are not found.
Please refer https://docs.nvidia.com/jetson/archives/r36.4.3/DeveloperGuide/SD/Communications/AudioSetupAndDevelopment.html#source-sink-widget-not-found section to root cause the issue.
If still facing issue, please share the logs and the DT log from the platform (command: “$ dtc -I fs -O dts /proc/device-tree >/tmp/dt.log”).
