Jetpack 6.2 PVA-SDK samples
Hi, I’m using orin nx devkit to test PVA. When I installed jetpack, I can see pva-sdk-2.5 is located in /opt/nvidia. However, it only contains lib and no sample in it.
In this docs, it says there exists sample in pva-sdk, but this doc is about version 2.7 while jetpack6.2 gives 2.5.
So, how can I get pva-sdk-samples?
You can submit the below form to apply for access:
