JetPack 6.x (L4T R36.4.3): How to completely disable PXE / Network Boot in UEFI?
For our deployment requirements, we need to completely disable and remove PXE boot / HTTP boot / Network booting options from UEFI, while keeping standard OS-level Ethernet networking fully functional once booted into Linux.
We noticed that:
  • Network boot options (UEFI PXEv4..., UEFI PXEv6..., etc.) are generated dynamically by UEFI at runtime.
  • Adjusting DefaultBootPriority in device tree overlays (L4TConfiguration.dtbo) does not suppress dynamic PXE enumeration.
Is there an officially supported configuration setting, device tree property, or UEFI variable in R36.4.3 to completely suppress/disable dynamic network boot candidate generation, or is patching and rebuilding the UEFI source binary the only way to achieve this?
Hi aicouldntcrackit,
Are you using the devkit or custom board for Orin Nano?
You can refer to the following thread for this use case.
在烧写系统前,如何把httpv6,httpv4,pxev6,pxev4在uefi菜单中禁掉 - #14 by 1516775545
