We are doing JetPack 7.1 A/B OTA test, we found that some directories and files are not being
updated, such as the boot and home directories. Please help us check the cause,thank you.
The upgrade method refers to Topic 358606.
hello Ethan_su,
please note that, JetPack 7.2/r39.2 is now available,
please moving forward to the lates release version for verification. thanks
A/B OTA on Jetson updates the rootfs partition that is not currently active, then switches the boot slot. If some files are “not updated,” the usual causes are:
1. The files live in a persistent partition, not the A/B rootfs. /opt, /usr/local, /home, /var, and anything mounted from APP_b or custom partitions are intentionally preserved across updates. Check /proc/mounts and your flash layout.
2. The OTA payload did not include those packages. If you built a custom BSP or used a partial OTA, confirm the deb packages / overlay contents are in the payload. apt list --installed on the new slot should show the expected versions.
3. Boot slot did not switch. After OTA, check sudo nvbootctrl get-current-slot and sudo nvbootctrl dump-slots. If it’s still slot 0, the update applied to slot 1 but the system never booted from it.
4. OTA was interrupted. A/B updates are atomic only if they finish. If power was lost mid-update, the inactive slot may be half-written and the bootloader falls back.
Diagnostic commands:
- sudo nvbootctrl get-current-slot
- sudo nvbootctrl dump-slots
- cat /etc/nv_tegra_release
- Compare /proc/mounts against your flash.xml layout.
Post the output of the first two and which directories are stale, and I can tell you whether it’s a partition-layout issue or an OTA payload issue.
