JetPack 7.1 with Jetson Linux 38.4缺少nvidia-l4t-gstreamer_38.4.0-arm64.deb和nvidia-l4t-jetson-multimedia-api_38.4.0_arm64.deb
ga的38.4.0 缺少nvidia-l4t-gstreamer_38.3.0-20251125121115_arm64.deb和nvidia-l4t-jetson-multimedia-api_38.3.0-20251125121115_arm64.deb 这两个deb 需要38.4.0的deb,nvidia-l4t-gstreamer_38.4.0-arm64.deb和nvidia-l4t-jetson-multimedia-api_38.4.0_arm64.deb预计什么时候发布?
The JetPack7.1 release is ongoing, please wait for our announcement,
Now there are packages that you can download or install.
But I think the two packages may need to be rebuilt. They depend on some cuda-13.0 packages. That would be a problem for me as I have installed cuda-13.1.
apt download nvidia-l4t-jetson-multimedia-api
apt download nvidia-l4t-gstreamer
sudo apt install nvidia-l4t-jetson-multimedia-api nvidia-l4t-gstreamer
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
nvidia-l4t-gstreamer is already the newest version (38.4.0-20251230160601).
The following additional packages will be installed:
  cuda-cccl-13-0 cuda-cudart-13-0 cuda-cudart-dev-13-0 cuda-culibos-dev-13-0 cuda-driver-dev-13-0
  cuda-toolkit-13-0-config-common
The following NEW packages will be installed:
  cuda-toolkit-13-0-config-common nvidia-l4t-jetson-multimedia-api
0 upgraded, 7 newly installed, 0 to remove and 4 not upgraded.
Need to get 78.1 MB of archives.
After this operation, 120 MB of additional disk space will be used.
Do you want to continue? [Y/n] n
The JP 7.1 was released with CUDA 13.0.
For CUDA 13.1 support, customers need to rebuild the deb by themselves.
Sorry for that.
Can you confirm wherther you can install them successfully now?
可以下载了,正常尝试能否预安装到系统rootfs里面
