JetPack 7.2.1 - [Warn] Unknown power adapter detected: unexpected shutdowns may occur!
Dear Nvidia Team
With JetPack 7.2.1, we get the following warning on our custom carrier:
With JetPack 7.2, we have never seen such a message.
Can you elaborate?
Thank you.
Hi sevm89,
JetPack 7.2.1 adds a new power-adapter identification check on Thor, so this warning can appear if the system cannot read valid PD/CCG adapter identity information from the USB-C power path.
So this is not necessarily a real power issue; it can also be a false alarm, especially if the board is using non-standard or previously modified PD/CCG firmware.
Hi KevinFFF
Thank you for the explanation.
Is there a way to prevent this message?
Can we just uninstall the package nvidia-l4t-power-adapter-check? This also removes the package nvidia-l4t-bsp. For what is this package and is it okay to also remove it?
I would not suggest removing nvidia-l4t-power-adapter-check if that also removes nvidia-l4t-bsp: the first package is what shows this warning, and the second is part of the core Jetson/Thor BSP package set.
If you only want to stop the message, it is safer to disable the warning hook itself instead of removing BSP packages, but that only hides the message and does not fix the real PD/CCG detection problem underneath.
On our custom board, we do not have a PD/CCG adapter. What do you mean with detection problem underneath? How can we then just disable the warning hook?
If your custom board does not use PD/CCG for power input, then this warning does not really apply to your board. It was added for Thor devkit power-adapter detection, which depends on the PD/CCG path.
To disable it, remove or comment out below line in both /etc/pam.d/common-session and /etc/pam.d/common-session-noninteractive:
session optional pam_exec.so /usr/sbin/nv_pam_power_adapter_checker.sh
