Jetpack 7.2 DP Alt Mode support on Thor dev-kit
Hello, I recently upgraded my Thor dev-kit to Jetpack 7.2. The NVIDIA Jetson Linux Developer Guide claims that DP Alt Mode is supported using PD controller and re-driver, but I cannot find further information on how to set this up. I’m able to connect USB devices (such as keyboard and mouse on a USB hub) to J82 and flashed with J81. Is there any further guidance on setting up DP Alt mode on the Thor dev-kits?
Jetson Thor Series — NVIDIA Jetson Linux Developer Guide .
Jetson Thor Series — NVIDIA Jetson Linux Developer Guide.
If I understand @WayneWWW in this post https://forums.developer.nvidia.com/t/jetpack-7-2-usb-c-dp-altmode-with-no-usb-passthrough/378555/7 implies that it should work out of the box. The key part is "tested that the DP itself + USB device would work fine when both of them are connected on a hub that supports DP-ALT.
I think this is the driver
lsmod |grep ucsi_ccg
ucsi_ccg               20480  0
typec_ucsi             45056  1 ucsi_ccg
modinfo ucsi_ccg
No, it is not supported out of the box.
A NV devkit situation is different from custom board case. What I told in above link is just if a custom board handles their USB solution correctly, then rel-39.2 will support DP-ALT mode.
NV devkit by default does not support it because of the USB side issue.
