Hey, I installed the new operating system with JetPack 7.2. I wanted to enable the firewall to restrict networking. I tried to run the jetson-firewall, but could not install the Jetson-Platform-Services. I have tried with apt but they were not found. But I read they rely on normal ufw, so I installed ufw. When running ufw enable I get kicked out of the SSH session (I allowed port 22 for SSH before enabling):
ERROR: problem running ufw-init
iptables-restore v1.8.10 (nf_tables):
line 63: RULE_APPEND failed (No such file or directory): rule in chain ufw-not-local
line 26: RULE_APPEND failed (No such file or directory): rule in chain ufw-after-logging-input
line 27: RULE_APPEND failed (No such file or directory): rule in chain ufw-after-logging-forward
line 28: RULE_INSERT failed (No such file or directory): rule in chain ufw-logging-deny
line 29: RULE_APPEND failed (No such file or directory): rule in chain ufw-logging-deny
line 30: RULE_APPEND failed (No such file or directory): rule in chain ufw-logging-allow
line 34: RULE_APPEND failed (No such file or directory): rule in chain ufw-user-limit
ip6tables-restore v1.8.10 (nf_tables):
line 26: RULE_APPEND failed (No such file or directory): rule in chain ufw6-after-logging-input
line 27: RULE_APPEND failed (No such file or directory): rule in chain ufw6-after-logging-forward
line 28: RULE_INSERT failed (No such file or directory): rule in chain ufw6-logging-deny
line 29: RULE_APPEND failed (No such file or directory): rule in chain ufw6-logging-deny
line 30: RULE_APPEND failed (No such file or directory): rule in chain ufw6-logging-allow
line 34: RULE_APPEND failed (No such file or directory): rule in chain ufw6-user-limit
Problem running '/etc/ufw/before.rules'
Problem running '/etc/ufw/user.rules'
Problem running '/etc/ufw/user6.rules'
client_loop: send disconnect: Connection reset
When checking the device directly, ufw status is active and port 22 is allowed, but I can’t reconnect or ping. Also, systemctl status shows that ufw is inactive.
Does it work on Jetpack 6.2.2 r36.5? It seems like we don’t provide this alternative for Orin. If it works on Jetpack 6, please share where you get the guidance.
So, the Jetson-Platform-Services have a “current release runs on JP 6.1 GA (BSP R36.4.0) or JP 6.2 (BSP R36.4.3).” according to the documentation:
Release Notes (version 2.0) — Jetson Platform Services documentation
As this is outdated for my version I tried normal ufw as described in the following forum post:
Missing firewall service - Jetson Systems / Jetson AGX Orin - NVIDIA Developer Forums
But the service crashes as described.
Please use latest Jetpack 6: 6.2.2 r36.5, to run Jetson Platform Services.
You may want to, while at the Orin console run following to clear ufw.
sudo ufw disable
sudo ufw --force reset
Looking at a downloaded extracted nvidia-jetson-services_2.0.0_arm64.deb, the following mirrors on Jetpack 7.2 the configuration found in /opt/nvidia/jetson-2.0.0/services/firewall/bin/jetson-firewall.sh.
sudo bash <<'EOF'
set -e
IPT=iptables
# Flush the existing IPv4 rules and user-defined chains.
$IPT -F
$IPT -X
$IPT -t nat -F
$IPT -t nat -X
$IPT -t mangle -F
$IPT -t mangle -X
$IPT -t raw -F
$IPT -t raw -X
# Temporarily allow traffic while constructing the ruleset.
$IPT -P INPUT ACCEPT
$IPT -P FORWARD ACCEPT
$IPT -P OUTPUT ACCEPT
# Always allow loopback traffic.
$IPT -A INPUT -i lo -j ACCEPT
$IPT -A OUTPUT -o lo -j ACCEPT
# Allow replies to connections initiated by this computer.
$IPT -A INPUT \
-m conntrack --ctstate ESTABLISHED,RELATED \
-j ACCEPT
# Allow replies from this computer to permitted incoming connections.
$IPT -A OUTPUT \
-j ACCEPT
# Drop malformed/invalid connection state.
$IPT -A INPUT \
-m conntrack --ctstate INVALID \
-j DROP
$IPT -A OUTPUT \
-j DROP
# Incoming SSH.
$IPT -A INPUT -p tcp --dport 22 \
-m conntrack --ctstate NEW \
-j ACCEPT
# Incoming DNS: UDP for normal queries and TCP for large responses/transfers.
$IPT -A INPUT -p udp --dport 53 \
-j ACCEPT
$IPT -A INPUT -p tcp --dport 53 \
-j ACCEPT
# Incoming HTTP and HTTPS.
$IPT -A INPUT -p tcp --dport 80 \
-j ACCEPT
$IPT -A INPUT -p tcp --dport 443 \
-j ACCEPT
# Incoming Redis.
$IPT -A INPUT -p tcp --dport 6379 \
-j ACCEPT
# Outgoing TCP port 30099.
$IPT -A OUTPUT -p tcp --dport 30099 \
-j ACCEPT
# If you really, really want to lock down your Orin uncomment next 3 lines.
# $IPT -P INPUT DROP
# $IPT -P FORWARD DROP
# $IPT -P OUTPUT DROP
EOF
