JetPack 7.2 / L4T 39.2 NITO support for more than 8 sensor modes
I am migrating our camera tuning to NITO on Jetson AGX Orin with JetPack 7.2 / L4T r39.2, using the Argus camera stack.
Our camera driver exposes 15 sensor modes, and we need all 15 modes to remain available through Argus.
However, when looking at the NITO tuning structure/template and the sensor-mode-to-knobset mapping, it appears that only 8 sensor modes can be represented/mapped.
How should a NITO file be configured for a sensor that exposes 15 modes?
Specifically:
  • Is there a limit on the number of sensor modes that can be represented in an Argus NITO file?
  • Can the mode-to-knobset lookup table be extended to contain all 15 sensor modes?
  • If multiple sensor modes use exactly the same ISP tuning, can all 15 sensor modes be mapped to the same knobsetMode / knobset ID?
  • If the NITO schema itself only provides entries for 8 modes, what is the supported NVIDIA workflow for cameras exposing more than 8 modes?
  • Is this limitation related to the NITO schema/tuning library, or is there another configuration that controls the maximum number of modes?
The goal is not to create different tuning for every sensor mode. Ideally, all 15 sensor modes would use the same tuning, but all 15 modes still need to be available to Argus.
Could you please clarify the supported way to configure this in the JetPack 7.2 Camera Partner Toolkit/NITO workflow?
hello l.strmo,
unfortunately, it’s current limitation. NITO supports at most 8 mode2KnobLUT entries in JP-7.2 release version.
