Is the Jetpack package that is used in Jetson Orin Nano can be reused with Jetson Nano. Will it be compatible for both?
No, they are not compatible.
FYI, the first Nano is a TX1 in small form factor. Note that L4T is what actually gets flashed, and in turn this is just Ubuntu plus NVIDIA drivers. You can find which releases are compatible here:
https://developer.nvidia.com/linux-tegra
