I’ve downloaded and installed JetPack for TK1 in an Ubuntu 14.04 VM.
Having been through the installation steps, I’ve managed to successfully push and install JetPack onto my TK1.
What I would like to do now is push this to many TK1 boards. Is there a simple way of running the “push” script rather than going through the entire installation process again?
Kind regards,
Kevin
You can clone. See:
[url]http://elinux.org/Jetson/Cloning[/url]
Basically you set up a reference TK1 as you want it, then clone. This replaces “system.img” during command line flash and re-uses the system.img rather than generating a new one. You can clone and restore “ALL” partitions, and not just the rootfs (“APP”), but the rootfs (“APP”) is loopback mountable and can be updated/edited/examined (you could loopback mount rootfs on the host and rsync from a Jetson for minor updates).
