We built a docker on an Orin NX Jetpack 6.1 and we want to deploy it on an Orin NX that’s using Yocto.
We can run the docker engine but when we try and run code from the docker it reports several errors.
Since jetpack 5, I thought dockers would containerise everything that’s needed like Cuda and tensorRT etc?
Can you point us in the direction of what might be causing these issues.
