13:22:24 ERROR : NVIDIA Nsight Systems : update-alternatives: error:
13:22:24 ERROR : NVIDIA Nsight Systems : alternative path is not absolute as it should be:
13:23:51 ERROR : CUDA on Host : Extracting templates from packages: 33%
13:23:52 ERROR : CUDA on Host : Extracting templates from packages: 67%
13:23:52 ERROR : CUDA on Host : Extracting templates from packages: 100%
13:27:44 ERROR : OpenCV on Host : dpkg: dependency problems prevent configuration of libopencv:
13:27:44 ERROR : OpenCV on Host : dpkg: error processing package libopencv (–install):
13:27:44 ERROR : OpenCV on Host : Errors were encountered while processing:
13:27:44 ERROR : OpenCV on Host : libopencv
13:27:45 ERROR : OpenCV on Host : E
13:27:45 ERROR : OpenCV on Host : :
13:27:45 ERROR : OpenCV on Host : Unmet dependencies. Try using -f.
13:30:19 ERROR : CUDA Cross Compile Package on Host : Extracting templates from packages: 85%
13:30:19 ERROR : CUDA Cross Compile Package on Host : Extracting templates from packages: 100%
I don’t know why this ERROR is happening. how can i do for this Please help me.
I make that tools and install python2.7 in my host computer
I’m installing cuda after hearing your answers.
sudo apt install nvidia-cuda-toolkit
using this code
so i install nvcc, my nvcc version
Copyright (c) 2005-2015 NVIDIA Corporation
Built on Tue_Aug_11_14:27:32_CDT_2015
Cuda compilation tools, release 7.5, V7.5.17
kaycc after install nvcc i have same ERROR in my host computer
14:51:48 ERROR : NVIDIA Nsight Systems : update-alternatives: error:
14:51:48 ERROR : NVIDIA Nsight Systems : alternative path is not absolute as it should be:
14:53:29 ERROR : CUDA on Host : Extracting templates from packages: 55%
14:53:29 ERROR : CUDA on Host : Extracting templates from packages: 100%
14:57:28 ERROR : OpenCV on Host : dpkg: dependency problems prevent configuration of libopencv:
14:57:28 ERROR : OpenCV on Host : dpkg: error processing package libopencv (–install):
14:57:28 ERROR : OpenCV on Host : Errors were encountered while processing:
14:57:29 ERROR : OpenCV on Host : E
14:57:29 ERROR : OpenCV on Host : :
14:57:29 ERROR : OpenCV on Host : Unmet dependencies. Try using -f.
14:59:48 ERROR : CUDA Cross Compile Package on Host : Extracting templates from packages: 85%
14:59:48 ERROR : CUDA Cross Compile Package on Host : Extracting templates from packages: 100%
Thank you very much. Please take your advice.
I solved the ERROR.
Selecting a new pc, installing the 18.04 version of ubuntu, and connecting and installing the pc and jetson in the same hub network was a success.
