I am using above mentioned nvdia sdk manager to download jetpack on the AGXI board - which is giving error as shown above.
Using OTG port on the AGXI device to connect it with native Linux laptop - Ubuntu 20.04.
This is not working as shown above, please guide what can be the issue.
Nirav
kayccc
#2
Are you connect type-C flash cable on J512 port?
Please try below steps do the flash manually:
- Put device into recovery mode by manually
- Use ‘lsusb’ to check Xavier into RCM success on host machine
- Go to Linux_for_Tegra folder
- Flash image by manually:
$ sudo ./flash.sh jetson-agx-xavier-industrial mmcblk0p1
