I am going to install OpenCV on Jetson TX2 by JetPack Installer 3.3.1. I input the IP, username and password as required. However, the installer seems make no more response after I clicking “Next”. The only change on UI is that the “Next” button became disabled.
So is there anything wrong in my operation or this an error of Jetpack installer? How can I fix it? Thanks a lot!
P.S.
I am sure that my IP, username and password is correct as I have tried to connect my Jetson directly by ssh and it worked. Also, I’ve tried to input wrong things and installer will pop out a window to report error instead of being silence.
I also tried JetPack 2.2.1 installer and this problem happened too.
