My computer chip is AMD CPU. I installed JetPack4.5 using ubuntu18.04 system in VMware virtual machine software. When the download is complete and I start flashing, there is a problem, and it has been unable to proceed successfully. The “creating OS image” step appears. If the problem is encountered, it cannot be done when flashing components such as “cuda” to the host. After trying various methods, it has not been solved. When the same virtual machine was opened on the Intel CPU computer, the task of flashing was successfully completed. So I think the SDK Manager-JetPack or Ubuntu system has compatibility issues with AMD CPUs and cannot support them well. Please help me to solve this problem, thanks.
It is very compatible with the AMD CPU. It is a specific package or packages which failed due to a missing dependency. Looks like it is NVIDIA Nsight which is failing install. I couldn’t tell you from that screenshot what requirement needs to be installed before Nsight would work, but if you look near the bottom, there is an “EXPORT LOGS
” function. You could export logs and then upload that to the forums and someone could probably provide more information on what needs to be added for Nsight to be installed.
感谢,我已经解决了,确实是因为缺少依赖。我一直错误的认为不兼容问题,后来发现是网络不佳导致下载包不完整。
