Hello good morning, I have had this error for 2 days, I put an m2 to the agx but when migrating the files it was damaged and it did not start, what I tried to do is reinstall the os but when I install it the following appears, I don’t know what should it be, any ideas?
Looks your Xavier device doesn’t into recovery mode.
Please try put device into recovery mode by manually and flash again.
Are you connect type-C cable on J512 port?
Before flash, please using ‘lsusb’ command to check you can see the device.
