planning to provide updates to the already deployed autonomous machine based on jetpack and Jetson Orin device. does Nvidia has example reference for for Over the Air(OTA) updates? and possibly have jetpack in the CI build process
Hello @ramkumarkoppu,
We would recommend checking out NVIDIA documentation on OTA.
Also, it is important to determine the following before creating an update procedure.
If you share a bit more details about your scenario we might be able to give you a hand with the process of designing the update procedure tailored for your system.
Please do not hesitate to reach out if you require further help.
regards,
Andrew
Embedded Software Engineer
ContactUs: support@proventusnova.com
www.proventusnova.com
