Hi ,
Is there a possibility of rollback of Jetpack from 4.5.2 to 4.5.1? Also can anyone suggest backup tools for Nvidia AGX Xavier, every time after flashing all the config is lost, even for the Isaac SDK all dependencies have to be installed?
Hi ,
Are you trying to run Isaac SDK 2021.1 applications on Jetpack 4.5.2 and it is failing? Isaac SDK has only been tested on Jetpack 4.5.1 but there is a good possibility that it should work fine on Jetpack 4.5.2. Otherwise, you’ll have to reflash the AGX Xavier and start from scratch again. You can manually backup files that you want of course but it will be reset to factory defaults again.
