JetPack software has been not installed
Hi, I have flashed the Jetson TX2 and it is running ok but I don’t have intalled the software that comes with JetPack or at least I suppossed that it comes with the installation.
I am referring to TensorRT, cudNN, etc. It is suppossed that it have to be included?
Hi omarorgeira,
The TensorRT and CuDNN needs to be installed within the JetPack.
Please refer to the [url]https://docs.nvidia.com/jetpack-l4t/index.html#jetpack/3.3/introduction.htm[/url] and [url]https://docs.nvidia.com/jetpack-l4t/index.html#jetpack/3.3/install.htm[/url]
Note: JetPack can flash, but you can uncheck flash and run it at any time just to install software to either PC host or to Jetson. The trick is that if you haven’t flashed, then you must manually give it the IP address when requested…watch the console during run to make sure you haven’t missed the login address prompt.
