Jetpack stuck during installation
Dear,
When I Install Jetpack for TK1, the process stuck at Post Installation.
I tested both L4T-2.3.1 and L4T-3.0, and same results.
Screenshot is here: https://drive.google.com/file/d/0B9g4OeFMnBi5S3V2S2M0RnhjQjQ/view?usp=sharing
– modified to additional info.
– console says,
sending file: system.img
     \ 73400320/2373112356 bytes sent
Everytime, installation job stopped here, and TK1 cannot boot properly.
Any kind of comment will be appreciated.
mipsan
Hi mipsan,
Please try below steps to flash image:
sudo tar xpf Tegra124_Linux_R21.5.0_armhf.tbz2 cd Linux_for_Tegra/rootfs/
sudo tar xpf ../../Tegra_Linux_Sample-Root-Filesystem_R21.5.0_armhf.tbz2 cd …
sudo ./apply_binaries.sh sudo ./flash jetson-tk1 mmcblk0p1
Download link: https://developer.nvidia.com/embedded/downloads
Additional question: Is there anything special about the host, e.g., is it a VM? Also, does it stop and different percent completions, or is it always at the same exact spot?
I installed JetPack on the VM. And always stopped at the same position.
Thanks,
I will try this !
Thanks all,
The reason is VM. After change the host to real-host, everything is OK.
