Hi.
Thank you for always quick help.
We are developing a vehicle solution based on Tx2 based target board.
We are using an LTE module with an onboard USB interface.
On the same board
In Jetpack 3.2, the recognized module
nvidia@tegra-ubuntu:~ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
<u>Bus 001 Device 003: ID 1ecb:0205 </u>
Bus 001 Device 002: ID 0424:2513 Standard Microsystems Corp. 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
nvidia@tegra-ubuntu:~ uname -a
Linux tegra-ubuntu 4.4.38 #1 SMP PREEMPT Fri Apr 19 16:14:24 KST 2019 aarch64 aarch64 aarch64 GNU/Linux
It will not be recognized until after Jetpack 4.2 is installed.
Linux tegra-ubuntu 4.9.140 #1 SMP PREEMPT Mon Apr 22 09:41:33 KST 2019 aarch64 aarch64 aarch64 GNU/Linux
Power Voltage was found to be OK.
Dmesg check result did not show any special message when I plug it in again.
I did not do anything special about USB.
Is there a fix for USB interface in Jetpack 4.2?
How can I debug it?
