Jetpack6.0 GA vst added stream successfully, but could not play
jetpack6.0 GA vst added stream successfully, but could not play ,
I also tested deepstream-server add stream but also add failed and reply 500 code。
I used jetson6.0DP version of the fix way, running install.sh has no effect
Regarding deepstream-server, can you have a try with below command line?
$ sudo apt install libgstrtspserver-1.0-*
$ touch /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_deepstream_bins.so
$ gst-inspect-1.0 nvurisrcbin
Thank you very much for the solution, it worked
