Jetpack6.0 Installation failed on jetson osrin NX
15:38:50 ERROR: Flash Jetson Linux - flash: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
15:38:50 ERROR: Flash Jetson Linux - flash: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
15:39:15 ERROR: Flash Jetson Linux - flash: 77459 blocks
15:39:39 ERROR: Flash Jetson Linux - flash: 130233 blocks
15:42:12 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.ubuntu.sh; [error]: 130233 blocks
15:42:12 ERROR: Flash Jetson Linux - flash: command terminated with error
15:42:12 SUMMARY: DateTime Target Setup - target: Depends on failed component
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_Orin_NX_modules_2024-09-18_14-57-11.zip (237.2 KB)
I need help
The error log is this one.
15:42:12.287 - Info:Timeout
Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
Is this NV devkit or custom board?
NV devkit, I tried ,still failed
18:30:41 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.ubuntu.sh; [error]: 130233 blocks
18:30:41 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
18:30:41 INFO: Flash Jetson Linux - flash: [host] [ Disk Avail on Partition : 0.00 B ]
18:30:41 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 26m53s ]
18:30:41 ERROR: Flash Jetson Linux - flash: command terminated with error
18:30:41 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
18:30:41 SUMMARY: Multimedia API - target: Depends on failed component
18:30:41 SUMMARY: TensorRT on Target - target: Depends on failed component
18:30:41 SUMMARY: TensorRT Runtime - target: Depends on failed component
18:30:41 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
18:30:41 SUMMARY: CUDA Runtime - target: Depends on failed component
18:30:41 SUMMARY: CuDNN on Target - target: Depends on failed component
18:30:41 SUMMARY: CuDNN Runtime - target: Depends on failed component
18:30:41 SUMMARY: OpenCV - target: Depends on failed component
18:30:41 SUMMARY: OpenCV Runtime - target: Depends on failed component
18:30:41 SUMMARY: VPI on Target - target: Depends on failed component
18:30:41 SUMMARY: Jetson Platform Services - target: Depends on failed component
18:30:41 SUMMARY: VPI Runtime - target: Depends on failed component
18:30:41 SUMMARY: CuPVA Runtime - target: Depends on failed component
18:30:41 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
18:30:41 SUMMARY: Nsight Systems - target: Depends on failed component
18:30:41 SUMMARY: Nsight Graphics - target: Depends on failed component
18:30:41 SUMMARY: Gstreamer - target: Depends on failed component
18:30:41 SUMMARY: DLA Compiler - target: Depends on failed component
18:30:41 SUMMARY: DateTime Target Setup - target: Depends on failed component
如果你要附上flash log就照一開始那樣給zip file… 你自己貼的其實都不是太相干的log…
也請你在燒錄的時候抓serial console log然後一起附上來.
你好,我重新烧录了还是失败,系统烧录不上,如下是日志
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_Orin_NX_modules_2024-09-20_10-32-41.zip (204.9 KB)
你還是沒附上serial log阿…請問前面的comment真的有看懂嗎?
還有我們現在只是請你抓log. 還沒有提供任何解法 …
