Jetpack6.0 有适配的wifi模块吗?
orin nano4g,系统版本为jetpack6.0, intel 8265NGW 无线网卡, 此款网卡不是免驱动的嘛, 在6.0版本上,lspci能识别到设备,但是没有wifi图标
不用額外裝driver沒錯 但是你要在kernel裡開起來才能用
https://wiki.gentoo.org/wiki/Iwlwifi
在这个链接中我没识别出来哪个是开启的步骤,能麻烦你这边给标注一下吗?
進到Linux_for_Tegra/source/kernel/kernel-jammy-src/之後
make ARCH=arm64 defconfig
make ARCH=arm64 menuconfig
(用選單開你要的東西)
make ARCH=arm64 savedefconfig
(把kernel-jammy-src/defconfig複製回kernel-jammy-src/arch/arm64/configs)
然後參考下面文件build kernel
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/Kernel/KernelCustomization.html
执行到make -C kernel这一步时,有错误提示。
以下是提示内容:
nvidia@ubuntu:~/36.3.0/Linux_for_Tegra/source$ sudo make -C kernel
make: Entering directory '/home/nvidia/36.3.0/Linux_for_Tegra/source/kernel'
Building kernel-jammy-src sources
make \
        ARCH=arm64 \
        -C /home/nvidia/36.3.0/Linux_for_Tegra/source/kernel/kernel-jammy-src  \
        LOCALVERSION=-tegra \
        defconfig
make[1]: Entering directory '/home/nvidia/36.3.0/Linux_for_Tegra/source/kernel/kernel-jammy-src'
*** Default configuration is based on 'defconfig'
# No change to .config
make[1]: Leaving directory '/home/nvidia/36.3.0/Linux_for_Tegra/source/kernel/kernel-jammy-src'
make -j 6 \
        ARCH=arm64 \
        --output-sync=target Image
  HOSTCC  scripts/sign-file
scripts/sign-file.c:25:10: fatal error: openssl/opensslv.h: No such file or directory
   25 | #include <openssl/opensslv.h>
compilation terminated.
make[2]: *** [scripts/Makefile.host:95: scripts/sign-file] Error 1
make[2]: *** Waiting for unfinished jobs....
  HOSTCC  scripts/extract-cert
scripts/extract-cert.c:21:10: fatal error: openssl/bio.h: No such file or directory
   21 | #include <openssl/bio.h>
make[2]: *** [scripts/Makefile.host:95: scripts/extract-cert] Error 1
make[1]: *** [Makefile:1250: scripts] Error 2
make: *** [Makefile:31: kernel] Error 2
make: Leaving directory '/home/nvidia/36.3.0/Linux_for_Tegra/source/kernel'
還有麻煩學一下怎麼貼log
把log放在```和```裡面
把log放在```和```裡面
把log放在```和```裡面
请问在哪里查jetpack6.0适配的网卡型号?
