Jetpack6.1 Rename Network
Hello, when I was using Jetpack 6.1, I noticed that the network naming convention has changed and is no longer using eth *.
At this point, modifying it back to eth * through the rules file will no longer take effect.
And upon checking dmesg, it was found that all modifications were made from eth0, rather than loading the network port names in order before making the changes.
May I ask how to adjust back to the previous loading method? Or is there a way to rename again?
Looking forward to your reply, thank you.
It looks to be behavior of the driver. Please check with the vendor for further information. The component is from 3rdprty and uses driver in upstream kernel. Would suggest consult vendor to know why it renames the network.
