JetPack6.1 USBSS2 working
Hi NV,
On our customer carrier board, the 4G module(Telit) is connected to USBSS2(3.0) and USB2(2.0), but lsusb -t SHOWS that only USB2.0 is connected. so my question is USBSS2(3.0) port is default enabled or disabled on NV devkit.
Jasper
20250115
need to review the connector and also the device tree too.
We could not test on NV devkit, so the only way is to help confirm whether USBSS2 if enable or disable on R36.4(Orin Nano/NX platform)? if default disable(devkit is connected to testpoint only), how to enable USBSS2, please give some software procedure, thanks!
Jasper
20250115
tegra234-p3768-0000+p3767-0000.dts.txt (2.2 KB)
tegra234-p3768-0000+p3767-xxxx-nv-common.dtsi.txt (7.2 KB)
USBSS2 part circuit for 4G-5G module.pdf (580.1 KB)
不知道你是不是沒看懂我的意思. 我上面講的是我們得review你的hardware線路(connector部份)跟device tree.
完全跟NV devkit無關
Hi Wayne
added schematic,FYI
  1. device tree請直接給dtb convert回來的版本. 不要傳source code.
  2. dmesg也請給出來
dmesg.txt (63.1 KB)
