Jetpack6 nvcsi link issue
Hi authors
My developing environment
・Module:Jetson orin nx 8G
・Carrier Board: Developer -kit
・Jetson Linux R36.4.3 / Jetson Linux R35.4.1
I am developing driver for my custom camera module.
My camera module composition below.
Cam0 port|—|Mux tca9546|—ch:1—|sensor_a@10
—ch:0—|power_ic
Under my jetson Linux R35.4.1 environment , custom developed driver & device tree works well.
So, I try to port device tree and device drivers in new R36.4.3 environment, but it doesn’t works it…
Device driver works as normal and tegra-capture-vi bind success, but media-pad link fail. Like below
Dmesg:
[ 9.312405] tegra-camrtc-capture-vi tegra-capture-vi: subdev sensor_a 16-0010 bound
Media ctrl link Fail & No /dev/video0 found
Media controller API version 5.15.148
Media device information
driver tegra-camrtc-ca
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 5.15.148
Device topology
  • entity 1: sensor_a 16-0010 (1 pad, 0 link)
    type V4L2 subdev subtype Sensor flags 0
    pad0: Source
So I checked this media link fail issue from dmesg, I found a cause which is seems to nvcsi issue from dmesg’s log.
dmesg:
[ 8.326267] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 16-0010
[ 8.326284] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with tegra-capture-vi
I tested to change sensor node like below for check my device tree’s remote-endpoint setting .
When test device tree setted that node, media link construct success and find /dev/video0
Cam0 port|—|Mux tca9546|—ch:1—xx
—ch:0—|power_ic
|—|sensor_a@10
Questions:
・What reason do you think about media link fail cause at R36.4.3, when cam0 connect to sensor_a throug tca9546?
・I think this fail caused by device tree’s remote-endpoint issue (or graph.c driver isuue),how to fix it at R36.4.3?
Best regards.
hello Orinbeginner_xyz,
you may refer to developer guide, Camera Driver Porting.
please see-also Topic 310858 for known changes when porting DTS from JP-5 to JP-6.
Hello Jerrychang
Thank for your replay!
I already checked and corresponded JP5-JP6 changes.
I modified my custom device trees are based on “tegra234-camera-imx219.dtsi” , “tegra234-p3767-camera-p3768-imx219-dual.dts”.
Path Changes and modified like below
		fragment-camera@0 {
		target-path = "/";
		__overlay__ {
			tegra-capture-vi  {
				status="okay";
				num-channels = <2>;
				ports {
					#address-cells = <1>;
					#size-cells = <0>;
					vi_port0: port@0 {
						reg = <0>;
						sensor_a_vi_in0: endpoint {
							port-index = <1>;
							bus-width = <1>;
							remote-endpoint = <&sensor_a_csi_out0>;
					vi_port1: port@1 {
						reg = <1>;
						sensor_a_vi_in1: endpoint {
							port-index = <2>;
							bus-width = <1>;
							remote-endpoint = <&sensor_a_csi_out1>;
			bus@0 {
				host1x@13e00000 {
					nvcsi@15a00000 {
						status="okay";
						num-channels = <2>;
						#size-cells = <0>;
						csi_chan0: channel@0 {
							reg = <0>;
							ports {
								#size-cells = <0>;
								csi_chan0_port0: port@0 {
									reg = <0>;
									sensor_a_csi_in0: endpoint@0 {
										port-index = <1>;
										bus-width = <1>;
										remote-endpoint = <&sensor_a_out0>;
								csi_chan0_port1: port@1 {
									reg = <1>;
									sensor_a_csi_out0: endpoint@1 {
										remote-endpoint = <&sensor_a_vi_in0>;
						csi_chan1: channel@1 {
							reg = <1>;
							ports {
								#size-cells = <0>;
								csi_chan1_port0: port@0 {
									reg = <0>;
									sensor_a_csi_in1: endpoint@2 {
										port-index = <2>;
										bus-width = <1>;
										remote-endpoint = <&sensor_a_out1>;
								csi_chan1_port1: port@1 {
									reg = <1>;
									sensor_a_csi_out1: endpoint@3 {
										remote-endpoint = <&sensor_a_vi_in1>;
				cam_i2cmux {
					/* CAM PORT0 */
					i2c_0:i2c@0 {
						tca9546_a@70{
							/* Camera module MUX Channel:0 */
							cam_mod_i2c_a@0 {
							/* Camera module MUX Channel:1 */
							cam_mod_i2c_a@1 {
								sensor_a_cam0: sensor_a_a@10 {
									compatible = "sony,sensor_a";
									/* I2C device address */
									reg = <0x10>;
									/* V4L2 device node location */
									devnode = "video0";
									mode0 { /* sensor_a mode_60fps */
										/*omitted*/
									ports {
										#size-cells = <0>;
										port@0 {
											reg = <0>;
											sensor_a_out0: endpoint {
												port-index = <1>;
												bus-width = <1>;
												remote-endpoint = <&sensor_a_csi_in0>;
					/* CAM PORT1 */
					i2c_1: i2c@1 {
						tca9546_c@70{
							cam_mod_i2c_c@0 {
							cam_mod_i2c_c@1 {
								sensor_a_cam1: sensor_a_c@10 {
									reg = <0x10>;
									devnode = "video1";
									mode0 { /* sensor_a_60fps */
										/*omitted*/
									ports {
										#size-cells = <0>;
										port@0 {
											reg = <0>;
											sensor_a_out1: endpoint {
												port-index = <2>;
												bus-width = <1>;
												remote-endpoint = <&sensor_a_csi_in1>;
			tcp: tegra-camera-platform {
				compatible = "nvidia, tegra-camera-platform";
				modules {
					cam_module0: module0 {
						badge = "jakku_front_RBP194";
						position = "front";
						orientation = "1";
						cam_module0_drivernode0: drivernode0 {
							pcl_id = "v4l2_sensor";
							sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/cam_i2cmux/i2c@0/tca9546_a@70/cam_mod_i2c_a@1/sensor_a_a@10";
					cam_module1: module1 {
						badge = "jakku_rear_RBP194";
						position = "rear";
						orientation = "1";
						cam_module1_drivernode0: drivernode0 {
							sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/cam_i2cmux/i2c@1/tca9546_c@70/cam_mod_i2c_c@1/sensor_a_c@10";
In our case, Sensor node position is under cam_i2cmux and tca9546(mux), So I device tree modified .
But If sensor driver probing success, media bus ctrl path connections seems to fail and /dev/video0 is not created.
*media ctrl error
serial
bus info
hw revision     0x3
Device topology
- entity 1: sensor_a 16-0010 (1 pad, 0 link)
pad0: Source
In JP6, dose sensor must put under cam_i2cmux?
If I want to put sensor node like below, how I should modify my device tree?
cam_i2cmux–i2c0@0–tca9546_a@70-cam_mod_i2c0@0–sensor_a@10
it’s also works without i2xmux.
your device topology looks incorrect, did you load the device tree overlay blob correctly?
please see-also r36.4.4 release note, see-also [4.1. Camera] and [4.2. Device Registration] section for more details.
Thank you for replay!
I will check release note and confirm my device tree node settings !
Is it incorrect way of build and applying a dtbo?
All i2c devices works well and enable to access these devices throw a i2c protocol.
But construction of media control path between sink and source are always failed.
[To build dtbo file]
I build as a overlay file “tegra234-p3767-camera-p3768-sensor_a-dual.dtbo” which is consist of “tegra234-p3767-camera-p3768-sensor_a-dual.dts” included with “tegra234-camera-sensor_a.dtsi”.
“tegra234-camera-sensor_a.dtsi” is a code shown you previous comment.
[Applying a dtbo file to jetson system]
I putted in to the /boot directory at that overlay file(.dtbo). And I activated that overlay file by a jetoson-io tool.
After that, I reboot jetson system entirely.
I confirm to that jetson-io tool add a new line in a jetson’s extlinux file, like below.
OVERLAYS /boot/tegra234-p3767-camera-p3768-sensor_a-dual.dtbo
please also note that, You can specify FDT alone. You can specify FDT + OVERLAYS. You cannot do only OVERLAYS though.
Overlays from Rootfs are processed only if DTB is coming from Rootfs. when FDT entry is not present in extlinux.conf UEFI DTB is used.
I tried some settings in my device-tree.
I found that when a sensor port node put under “cam_i2cmux/i2c@0/tca9456_a@70/mod_i2c@1/sensor_a@10” media-link between sensor ports and nvcsi must be failed some reason.
( Do not appear a device topology like that , “- entity 1: 13e00000.host1x:nvcsi@15a00000- (2 pads, 2 links”)
But it putted under “cam_i2cmux/i2c@0/sensor_a@10” , media link construction between sensor ports and nvcsi were always succeed.
( nvcsi media device topology appeared. )
I think ,It seems to can not track sensor port’s remote end point where is put under cam_i2cmux and tca9546 node by nvcsi driver or of_graph driver.
On the other hands, I2c bus node construction and connection with i2c protocol successes in a case which is under “cam_i2cmux/i2c@0/tca9456_a@70/mod_i2c@1/sensor_a@10”.
In “cam_i2cmux/i2c@0/tca9456_a@70/mod_i2c@1/sensor_a@10” case, How I should done succeed media link connection between nvcsi and sensor ports? Or is it my mistakes at device tree settings?
please visit tutorials page for the training slides of Develop a V4L2 Sensor Driver.
