I want to make a multi-flash image for JetPack 7.2 AGX Orin, flashing 5 units at a time. The previous 7.2 release was flashed with this package
Version 6.2.2 was working fine before
how should I do need help
Command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --use-backup-image --no-flash \
-p "-c bootloader/generic/cfg/flash_t234_qspi.xml --no-systemimg" \
--massflash 5 --network usb0 jetson-agx-orin-devkit-super internal
Error:
mkdir: cannot create directory '/tmp/.../initrd/usr/share/misc/': File exists
Script:
tools/kernel_flash/l4t_initrd_flash_internal.sh line 523:
mkdir "${working_dir}/initrd/usr/share/misc/"
Observation:
--massflash 5 calls generate_flash_initrd 5 times but reuses ${working_dir}/initrd.
JP6.x works, JP7.2 fails.
were generating the mfi package error
Please try to apply the patch from
Please apply the patch provided under the Linux_for_Tegra
Linux_for_Tegra$ patch -p1 < r39.2_Testing-massflash-backup.patch
r39.2_Testing-massflash-backup.patch (44.4 KB)
can use the patch in AGX ORIN? I need to make mfi pack in agx orin .
Please try to clean the directory and rerun the commands
sudo rm -rf /tmp/tmp.*
Should I apply the patch first and then perform the deletion, or does that patch only apply to Sol’s AGX Orin and not to mine, so I should just delete it directly? Many thanks.
sudo chmod 1777 /tmp
Then run the above command to create massflash.
Then use massflash to flash your boards.
Yes, please apply the patch.
