QSPI reported an error while burning.
May I ask what the reason is?
log as follows:
[ 29]: l4t_flash_from_kernel: Starting to flash to qspi
mtd_debug: error!: open()
Writing inode tables: done
Creating journal (131072 blocks): done
Writing superblocks and filesystem accounting information: done
Formatting APP parition done
Formatting APP partition /dev/nvme0n1p1 …
tar --checkpoint-action="ttyout=Hit %s checkpoint #%u%\r" -x -I ‘zstd -T0’ -pf /mnt/external/system.img --warning=no-timestamp --numeric-owner --xattrs --xattrs-include= -C /tmp/ci-h22DOI4QPV
writing item=17, 9:0:secondary_gpt, 61203267072, 16896, gpt_secondary_9_0.bin, 16896, fixed--0, 2cec870812124a0f6f8832d61ff5b594165dfd49
[ 153]: l4t_flash_from_kernel: Successfully flash the external device
[ 153]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
[ 153]: l4t_flash_from_kernel: Error flashing qspi
Flash failure
Either the device cannot mount the NFS server on the host or a flash command has failed. Check your network setting (VPN, firewall,…) to make sure the device can mount NFS server. Debug log saved to /tmp/tmp.gSNdTJeHdG. You can access the target’s terminal through “sshpass -p root ssh root@fc00:1:1:0::2”
Cleaning up…
