“Error Return value 4” when flashing a working yocto image to a Jetson-20-1-h1 Xavier-NX eMMC. This is the first time I’m encountering an issue flashing this image to this type of board. The only difference is the supplier of this kit (seeed studio). Tested flashing with working carrier board from NVIDIA, resulting in the same error code. When flashing, it stalls right after the NV3P_SERVER is accessing offset 20658 after boundary partition size 196608:
[ 108.4317 ] Writing partition bootloader-dtb_b with tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 109.7497 ] […] 100%
[ 109.7998 ] Writing partition BMP with bmp.blob
[ 111.1192 ] 0000000074740204: E> NV3P_SERVER: Accessing offset 206258 after boundary partition size 196608
[ 111.1579 ]
Error: Return value 4
Command tegradevflash_v2 --pt flash.xml.bin --create
Other relevant information: This was flashed from an Ubuntu 20.04.2 VM, as well as an Ubuntu 18.04 SMP machine with NVIDIA SDK Manager 1.8.0.10363 - Intel Celeron J4125 CPU - GNOME 3.28.2 64-bit System (both the VM and Ubuntu machine give the same error and behavior). Here is 3 seconds into the flash (relevant board information):
[ 3.5612 ] MB2 Applet version 01.00.0000
[ 3.6185 ]
[ 3.6242 ] Retrieving board information
[ 3.6258 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 3.6575 ] MB2 Applet version 01.00.0000
[ 3.7679 ] Saved platform info in chip_info.bin
[ 3.8064 ] Chip minor revision: 2
[ 3.8068 ] Bootrom revision: 0xf
[ 3.8072 ] Ram code: 0x0
[ 3.8075 ] Chip sku: 0xde
[ 3.8078 ] Chip Sample: non es
[ 3.8310 ]
[ 3.8314 ] Retrieving EEPROM data
[ 3.8315 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ubuntu/Yocto_DEV_Images/yocto_xavier_nx_05042022/cvm.bin.1Aa5c
[ 3.8328 ] MB2 Applet version 01.00.0000
[ 3.9543 ] Saved platform info in /home/ubuntu/Yocto_DEV_Images/yocto_xavier_nx_05042022/cvm.bin.1Aa5c
[ 4.0530 ]
[ 4.0531 ] Rebooting to recovery mode
[ 4.0551 ] tegrarcm_v2 --ismb2
[ 4.0560 ] MB2 Applet version 01.00.0000
[ 4.1108 ]
[ 4.1108 ] Rebooting to recovery mode
[ 4.1118 ] tegrarcm_v2 --reboot recovery
[ 4.1125 ] MB2 Applet version 01.00.0000
[ 4.2599 ]
Welcome to Tegra Flash
version 1.0.0
…then the error seen above.
