Jetson 4.6.0 Xavier (Micron 16Gbit) NX board MB1 boot issue
The Jetson 4.6.0 Xavier NX board (white label p/n 900-83668-0000-000, s/n 1795125122633) will not boot at MB1 with console error:
[ 7.9035 ] Sending bct_mem
[ 7.9689 ] […] 100%
[ 8.0042 ] 0000000000000102: E> NONE: Invalid value MemBct dram size: 0MB for slot: 0.
[ 8.0424 ]
Error: Return value 2
This issue is due to the SDRAM chip part number change.
We must remain on Jetson 4.6.0 / r32.6.1 initial release and need a patch to fix the Micron 16Gb NX version using the dev kit.
The current patches available are:
XNX-16GB-r32.6.1-overlay for the Hynix part, but we need support for the Micron 16Gbit part SDRAM[4] chip addition.
PCN210641 which supports Jetpack 4.5.1, not our version.
PCN21114 which supports Jetpack 5.1.2, not our version
Let me check with our internal team to see how to support the PCN211141 overlay on your JetPack 4.6 SW.
To clarify our current production version. JetPack 4.6 (L4T 32.6.1)
The PCN patch to use is unknown at this point, so we are asking for some direction to resolve this issue.
Thank you kindly,
David deGraaf
For the Jetson 4.6.0 Xavier NX board using the devkit board for flashing. We must remain on Jetson 4.6.0. Our current mode is secure boot “Production mode” fused, therefore the solution would need to support secure boot on both the old and new rev CPU/SOM, i.e., with and without the SDRAM[4] chip change. Our new rev SOM is RAMCODE 0x4 with I2cdump part level number: 699-13668-0001-302-B.0 and the old rev SOM is RAMCODE 0x0 with I2cdump part level number: 699-13668-0001-300-B.0
Please find the relevant overlay for PCN211141 from Jetson PCN Download Center | NVIDIA Developer
