Jetson 40 pin expansion header configuration
Hello again @KevinFFF after a long time, it took a long time to install sdk, but it was installed at the end, the problem is still not solved, it opens directly, works for 1 second and closes
Last disccusion :
Hi sentrycoder.dev0,
Do you mean that you use SDK Manager flashing your board but install SDK component failed?
SDK component should be installed after your first boot.
Could you share the flash log for further check?
no no i installed sdk there is no problem with it the problem is still jetson-io.py opens and ends instantly
Could you share the result of the following command on your board?
$ sudo ls -l /boot
total 58752
drwxr-xr-x 2 root root     4096 Eyl  5 23:59 dtb
drwxr-xr-x 2 root root     4096 Eyl  5 21:58 extlinux
drwxr-xr-x 2 root root     4096 Eyl  5 22:17 grub
-rw-r--r-- 1 root root 34707464 Eyl  5 21:44 Image
-rw-r--r-- 1 root root  7159654 Eyl  5 21:44 initrd
lrwxrwxrwx 1 root root       24 Eyl  5 22:16 initrd.img -> initrd.img-4.9.337-tegra
-rw-r--r-- 1 root root 15295123 Eyl  5 22:17 initrd.img-4.9.337-tegra
-rw-r--r-- 1 root root   228845 Eyl  5 21:44 kernel_tegra210-p3448-0000-p3449-0000-a02.dtb
-rw-r--r-- 1 root root     1077 Haz  9 07:25 tegra210-jetson-tx1-p2597-2180-a01-devkit-adafruit-sph0645lm4h.dtbo
-rw-r--r-- 1 root root     1073 Haz  9 07:25 tegra210-jetson-tx1-p2597-2180-a01-devkit-adafruit-uda1334a.dtbo
-rw-r--r-- 1 root root     1856 Haz  9 07:25 tegra210-jetson-tx1-p2597-2180-a01-devkit-csi.dtbo
-rw-r--r-- 1 root root   488509 Haz  9 07:25 tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
-rw-r--r-- 1 root root     2831 Haz  9 07:25 tegra210-jetson-tx1-p2597-2180-a01-devkit-fe-pi-audio.dtbo
-rw-r--r-- 1 root root     1304 Haz  9 07:25 tegra210-jetson-tx1-p2597-2180-a01-devkit-hdr30.dtbo
-rw-r--r-- 1 root root     3076 Haz  9 07:25 tegra210-jetson-tx1-p2597-2180-a01-devkit-hdr40.dtbo
-rw-r--r-- 1 root root     2111 Haz  9 07:25 tegra210-jetson-tx1-p2597-2180-a01-devkit-m2ke.dtbo
-rw-r--r-- 1 root root     2103 Haz  9 07:25 tegra210-jetson-tx1-p2597-2180-a01-devkit-respeaker-4-mic-array.dtbo
-rw-r--r-- 1 root root     2139 Haz  9 07:25 tegra210-jetson-tx1-p2597-2180-a01-devkit-respeaker-4-mic-lin-array.dtbo
-rw-r--r-- 1 root root   489038 Haz  9 07:25 tegra210-jetson-tx1-p2597-2180-a02-devkit-24x7.dtb
-rw-r--r-- 1 root root   228299 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a00.dtb
-rw-r--r-- 1 root root     1085 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a01-adafruit-sph0645lm4h.dtbo
-rw-r--r-- 1 root root     1081 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a01-adafruit-uda1334a.dtbo
-rw-r--r-- 1 root root   228259 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a01.dtb
-rw-r--r-- 1 root root     2839 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a01-fe-pi-audio.dtbo
-rw-r--r-- 1 root root     3700 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a01-hdr40.dtbo
-rw-r--r-- 1 root root     2119 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a01-m2ke.dtbo
-rw-r--r-- 1 root root     3344 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a01-mcp251x.dtbo
-rw-r--r-- 1 root root     2111 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a01-respeaker-4-mic-array.dtbo
-rw-r--r-- 1 root root     2147 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a01-respeaker-4-mic-lin-array.dtbo
-rw-r--r-- 1 root root     1121 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a02-adafruit-sph0645lm4h.dtbo
-rw-r--r-- 1 root root     1117 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a02-adafruit-uda1334a.dtbo
-rw-r--r-- 1 root root   228845 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a02.dtb
-rw-r--r-- 1 root root     2875 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a02-fe-pi-audio.dtbo
-rw-r--r-- 1 root root     3740 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a02-hdr40.dtbo
-rw-r--r-- 1 root root     2155 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a02-m2ke.dtbo
-rw-r--r-- 1 root root     3400 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a02-mcp251x.dtbo
-rw-r--r-- 1 root root     2147 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a02-respeaker-4-mic-array.dtbo
-rw-r--r-- 1 root root     2183 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-a02-respeaker-4-mic-lin-array.dtbo
-rw-r--r-- 1 root root   237352 Haz  9 07:25 tegra210-p3448-0000-p3449-0000-b00.dtb
-rw-r--r-- 1 root root   228655 Haz  9 07:25 tegra210-p3448-0002-p3449-0000-a02.dtb
-rw-r--r-- 1 root root   237198 Haz  9 07:25 tegra210-p3448-0002-p3449-0000-b00.dtb
-rw-r--r-- 1 root root     1077 Haz  9 07:25 tegra210-p3448-0003-p3542-0000-adafruit-sph0645lm4h.dtbo
-rw-r--r-- 1 root root     1073 Haz  9 07:25 tegra210-p3448-0003-p3542-0000-adafruit-uda1334a.dtbo
-rw-r--r-- 1 root root   229155 Haz  9 07:25 tegra210-p3448-0003-p3542-0000.dtb
-rw-r--r-- 1 root root     2831 Haz  9 07:25 tegra210-p3448-0003-p3542-0000-fe-pi-audio.dtbo
-rw-r--r-- 1 root root     3696 Haz  9 07:25 tegra210-p3448-0003-p3542-0000-hdr40.dtbo
-rw-r--r-- 1 root root     2103 Haz  9 07:25 tegra210-p3448-0003-p3542-0000-respeaker-4-mic-array.dtbo
-rw-r--r-- 1 root root     2139 Haz  9 07:25 tegra210-p3448-0003-p3542-0000-respeaker-4-mic-lin-array.dtbo
-rw-r--r-- 1 root root     2780 Haz  9 07:25 tegra210-p3448-all-p3449-0000-camera-imx219-dual.dtbo
-rw-r--r-- 1 root root     3036 Haz  9 07:25 tegra210-p3448-all-p3449-0000-camera-imx477-dual.dtbo
-rw-r--r-- 1 root root     2959 Haz  9 07:25 tegra210-p3448-all-p3449-0000-camera-imx477-imx219.dtbo
-rw-r--r-- 1 root root     2795 Haz  9 07:25 tegra210-p3448-common-imx219.dtbo
-rw-r--r-- 1 root root     2930 Haz  9 07:25 tegra210-p3448-common-imx477.dtbo
Is there any error message?
Could you also share the result of the following command?
$ cat /etc/nv_boot_control.conf
$ cat /etc/nv_tegra_release
i got an error only 1 time months ago related to python ncurses
Could you store the output to a file when you run jetson-io.py to check if there’s any message?
