I’m using an AGX with Jetpack 5.1.1. Our system uses 4 CSI cameras (Connect Tech Rogue Carrier Board with JCB005 Camera Adapter Board), and we notice that after a while, the streams stop capturing frames, but GStreamer isn’t crashing.
When a camera failure occurs, we notice when the fourth occurrence of the error below happens, a stream stops:
[ 1716.389079] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 4194404
[ 1985.877492] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 4194404
[ 2022.375924] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 4194404
[ 2064.474117] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 4194404
Furthermore, if we let Gstreamer continue, another camera failure will eventually follow with similar logging behavior. However, the err_data value is different:
[ 2698.946814] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 4194405
[ 2800.842440] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 4194405
[ 2960.135685] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 4194405
[ 3044.532002] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 4194405
I want to point out that the camera failure does not follow the device order. Among video0, video1, video2, and video3, the first failure consistently occurs in video2, followed by video3.
- Is there a reason why the failure order remains the same across different AGX systems we have tested (we have tried 4 identical systems)?
- Why does the error code vary depending on the camera? As mentioned, video2 has an err_data value of 4194404, while video3 has an err_data value of 4194405.
- Why does the error occur four times before the system completely fails? Is it because we are using four cameras?
- We also notice that when the error occurs, a CPU core becomes maxed out (we’re using all 8 cores). If 1 camera has failed, one core is maxed out. If 2 cameras fail, two cores are maxed out.
Thanks in advance for any assistance provided.
