Jetson AGX 5V Output Power on 40 pin header
I want to attach an LCD screen on the 40 pin header on the Jetson to communicate over SPI. It requires a 5V/1A power supply. I know the 40 pin header has a 5V output pin, but I am unable to find if it can handle 1A. Where can I find this information?
Hi @bh4216la
There is Table 3-4. 40-Pin Expansion Header Pin Description table
https://developer.download.nvidia.com/assets/embedded/secure/jetson/xavier/docs/Jetson_AGX_Xavier_Developer_Kit_Carrier_Board_Specification_SP-09778-001_v2.1.pdf?T7U07rHuZEw-MfAuEtpKu7Ll91DR9Uf2xytQ59l6JwI0VFik58cwxBu7vcyswfkogJZX3poi8Eg9gvpT4nn3WQ2SFtOiSYWAUfWDJl2hF6hm324JLVnldNZtUelGe8RTtmnuBo7-TqYhFAFCFzcenFQunsWs3b66QuYlkGwNIRG2LxNVsCymQDYNbyzpUbI5Wd5aQbDL-sme-9-ICAnH9_iHP92hWOUvTGxXw0Surl4oxnMHOehUy_sV#[{"num"%3A279%2C"gen"%3A0}%2C{"name"%3A"XYZ"}%2C81%2C720%2C0]
Regards
Great, thank you!
