Is there a GPIO that you can connect to, to reset the Jetson AGX development kit instead of using the reset button on the side of the development kit?
I see that there’s a pin labeled SYS_RESET_N on the automation header (J508), but that’s an output, so I don’t think it’s what I’m looking for.
hello bh4216la,
may I know what’s the actual use-case?
why don’t you simply use the commands, ($ sudo reboot
) to reset the board.
thanks
