I have a jetson AGX that was working fine with no problems. Once (due to some research activities), I connected the pin 4 (BUTTON_POWER_ON) of J508 to pin 1 (GND) in the carrier board.
After that, just connecting the power supply turns on the power led (no need to touch the power button) and there is no display signal on the screen. Of course, there is no jumper for an automatic boot.
I have tested the the power up sequence and the functionality of the button confirmed, but the problem still remained.
I have tried to go into recovery mode and connecting to the jetson through usb-c directly to linux, but it was not recognized, also tried to push the power on button for more than 10 seconds but it was not shutdown.
I have tried both (in fact i have tried all possible combinations…).
The point is that when i plug in the jetson, it starts directly (without the need of pressing the button). I am not sure if the problem comes from there and the jetson is not even starting to be able to debug.
We have connected the power to the wrong ping (due to some research activities in a custom product) and i am afraid that it is an error in some of the electrical components of the board.
I have carefully checked many things together with more colleagues and we were not able to find the problem.
If you have some suggestions on how to (at least) get some log or message let me know. Up to now the only message i can get is the one of my previous answer “GtkDialog mapped …”
