During use, I found that the interface using uart communication in the gpio port of xavier agx does not work properly. Can I specify other IO ports to work instead of the uart interface?
The same code works fine on jetson nano,When the jetson agx device is connected with a usb to TTL device, does the PWM signal light work? But under normal circumstances, the PWM does not light up when the usb is connected
