I’d like to understand how the Jetson AGX Industrial ‘Force Recover’ signal works as I have an application that needs to be fault tolerant.
From a hardware perspective: Does the ‘Force Recover’ force the Jetson to boot into Sector 0 where it is a hard-coded boot image and then allow you to use the peripherals such as TTY or Ethernet to re-image the runtime image (Sector 1). Once done I would assume there is some indication of success/fail of the re-flash of Sector 1 where the system can restart the Jetson and it would boot up using Sector 1 Flash image ?
Maybe there is a document that describes this that I haven’t seen yet ?
We are not using USB2 or USB3 or other peripherals and are limited to TTY and Ethernet.
