Jetson AGX JetPack 5.0.2 lose network connection after some minutes from reboot
CONDITIONS:
Jetson Board: Jetson AGX
JetPack: 5.0.2
I have recently flashed my AGX with JetPack 5.0.2.
After a power on, I connect to my AGX by ssh, but some minutes later, the ethernet connections is loset.
I noticed is that, when network connection is lost, if I connect a keyboard to my AGX (without loggin) the network connection returns, so I think the computer is suspending itself. So I disable automatic black screen and auto suspend capabilities from settings GUI, but this keeps happening.
I want to be able to connect to my AGX (with JetPack 5.0.2) by ssh in any moment, as is usual in JetPack 4.
Any help is welcome. Thank you.
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
hello marlon.ogosi,
did you configure power saving? please try disable it for testing.
in addition, please share kernel logs for reference.
