Jetson AGX Orin 32GB module no Display on Custom Board
Hello there,
We are trying to bring up our custom board with AGX Orin 32GB module and JetPack 5.0.2.
The following is our current configuration:
Blockquote
ODMDATA=“gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g”
*DCB file
dcb.txt (981 Bytes)
*Board dts file
tegra234-p3701-0004-p3737-0000.dts (434.8 KB)
*The debug UART log
debug_uart.txt (91.2 KB)
*Kernel dmesg
dmesg.txt (70.0 KB)
*Xorg log
Xorg.0.log.txt (13.8 KB)
We can see the UEFI log and logo on our screen, but nothing to show after kernel boot up. Could you please help have a look and give us some advice?
ODMDATA is not related to your issue. Also, you shouldn’t need to update dcb image because the default BSP already enabled DP.
We also tried the default dcb image, and it didn’t work neither.
if you put the module directly back to Orin AGX devkit, then will DP work there?
We have fixed the issue, please help close this thread. Thanks!
How did yo resolve this issue?
DP power enable gpio polarity on our board was different from that on devkit.
