Jetson AGX Orin 32gb not booting after flashing to JetPack 6.1
I have recently re-flashed my Jetson AGX Orin 32gb to JetPack 6.1 using a Ubuntu 22.04 host. However, after successfully flashed the and rebooting the Jetson shows no video on the monitor connected to it using DP cable. Please find attached the flashing log
flash-log.txt (102.8 KB)
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
Actually, the system boots normally but the problem is due to the DP to HDMI cable (that works with the old JetPack) no longer work in JetPack 6.1. I change new cable and see the new JetPack booting and running.
I am just curious about this as some other users also report that DP to HDMI cable has some problem.
Could you also test if jetpack6.0 has this issue or not? That would help clarify the problem.
If you don’t want to flash jp6.0, please at least dump me the /var/log/Xorg.0.log with your DP-> HDMI cable case on jp6.1.
Xorg.0.log (23.0 KB)
Sorry I can’t flash jp6.0 for testing but my previous jp5.1 had no problem with that DP->HDMI cable. It only happened after I had flashed to jp6.1
