According to the MCU code configured according to this power-on timing, I found that there was no output Carrier_power_on. Could you please advise me on how to troubleshoot this issue?
Which JetPack SW and on custom carrier board?
Can you please capture this rail with these signals in the same scope shot:
- SYS_VIN_HV
- MODULE_POWER_ON
- SYS_RESET_N
- CARRIER_POWER_ON
Trigger on HV rising and capture at least ~150ms after that edge.
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
Based on the provided context, I found a relevant topic that might help troubleshoot the issue.
In the topic “[Community Solution from Topic #309841]”, the user experienced a similar issue with their customized carrier board for the Jetson AGX Orin 64GB module. The problem was due to not properly handling the MODULE_POWER_ON signal.
The accepted solution suggests referencing the SN74LVC1T45DCKR from the Developer Kit to properly handle the MODULE_POWER_ON signal.
Additionally, the topic “[Community Solution from Topic #338689]” mentions that the issue might be related to the power sequence. The user’s power sequence was:
- 5V
- 12V
- module_power_on
- carrier_power_on
- 1.8V/3.3V
- sys_reset_n
However, the user did not provide the correct power sequence for the Jetson AGX Orin 64GB module.
To troubleshoot the issue, I recommend checking the power sequence and ensuring that the MODULE_POWER_ON signal is properly handled. You can refer to the Jetson AGX Orin Series Design Guide (including AGX Orin Industrial) to become familiar with the design and help guide you further debug the issue.
If you are using a custom carrier board, please ensure that the power sequence is correct and the MODULE_POWER_ON signal is properly handled. If the issue persists, please provide more information about your setup and configuration.
I could not find clear support for the MCU code configuration in the provided Jetson AGX Orin documentation. However, I hope the above information helps you troubleshoot the issue.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
Thanks, I have solved it
