Hello NVIDIA team,
I have a Jetson AGX Orin 64GB Developer Kit which is no longer entering recovery mode.
After a power overload, the device powers on (fan spins), but no HDMI output appears and the board is not detected on any host machine using the original USB-A to USB-C cable.
I’ve followed the correct recovery procedure multiple times:
- Hold REC, tap POWER, release REC
- Tried Reset + Recovery combination
- Used multiple laptops and confirmed cable is original
- Tried
lsusb
,dmesg
– no USB device appears
The fan works, indicating power is fine, but USB recovery mode is fully non-functional.
I suspect a failure in the USB controller or bootloader and would like to request help or an RMA/replacement under warranty.
Please advise.
Thank you.
