Jetson AGX Orin 64GB Developer Kit – Barrel-Jack Power Failure
We are experiencing a hardware failure with an NVIDIA Jetson AGX Orin 64GB Developer Kit, which is currently measuring 0 ohms across the power input barrel jack. Upon initial setup, we successfully powered and commissioned the device using the supplied power brick via the USB-C connector. However, when we integrated the Dev Kit into our application and attempted to power it through the barrel jack, the unit would not turn on. Our subsequent investigation revealed a dead short on the device’s main power rail. Because our application utilizes a highly regulated 9-36V DC-DC converter with an exceptionally clean output, we are confident our power supply did not cause this failure. We believe the Dev Kit was shipped with an underlying hardware defect that only manifested once the barrel jack was utilized.
The barrel jack is clear of debris and appears undamaged. When powered via USB-C, the fan and light turn on, and the Orin appears to boot normally. The short only appears on the rail supplied by the DC barrel jack.
We requested an RMA through Nvidia support (Incident: 260825-000161). They are requesting we open the issue here to determine whether the behavior is specific to the hardware unit.
We do use a DC power brick as a power supply at manufacturing.
I don’t know how and when the DC barrel jack got damaged but NV does not ship a DevKit with that kinds of issue on the DevKit.
