Jetson AGX Orin 64GB Developr kit JetPack Version
What version of JetPack is pre-installed in Jetson AGX Orin 64GB devkit?
Customer need to reflash it with JetPack SW after received.
I want to know the pre-installed version of JetPack.
If the version is different that I want, I will reflash it, but it will take some time, so I want to use it as is.
I don’t know which version ships, but on any Jetson which boots you can find the release with:
head -n 1 /etc/nv_tegra_release
(that’s the L4T release; JetPack release is the installer)
AFAIK, only factory SW are pre-installed, it’s not able to boot well after out-of-box. customer need to follow the get start instruction to flash the JetPack.
