Jetson AGX Orin 64GB Not Booting After Flashing OS to eMMC and NVMe
I’m working with the NVIDIA Jetson AGX Orin 64GB module on a Leetop carrier board .
I have flashed the OS multiple times first to the eMMC , and then to the NVMe SSD . During the flashing process, I encountered several errors, but I was able to resolve them. Both flashing attempts eventually completed successfully.
However, after the flashing process, there is no display output , and it seems the Jetson is not booting properly . The fan spins, the power LED is on, but there is no HDMI signal to the monitor.
I suspect this issue may be related to hardware compatibility, because I have NVIDIA Module and Leetop carrier board
Any help or troubleshooting guidance would be greatly appreciated.
Thank you!
We suggest to find a vendor to get the customized bsp.
Thank you for reply, I’ll check it
