Jetson AGX Orin 64GB UART connection with CubePilot X25-EVO causing boot issue
I am trying to connect a CubePilot X25-EVO flight controller to a Jetson AGX Orin 64GB via UART for MAVLink communication.
I connected the Jetson GPIO UART pins as follows:
Jetson Pin 8 (UART TX) → X25-EVO RX
Jetson Pin 10 (UART RX) → X25-EVO TX
Jetson Pin 6 (GND) → X25-EVO GND
After connecting these UART wires, the Jetson no longer boots into Ubuntu. It reaches the NVIDIA boot screen, but then the display becomes blank.
Could someone please advise:
  • Are these the correct UART pins for connecting an external flight controller?
  • Is this UART port reserved for the Jetson serial console and causing a boot conflict?
  • Do I need to disable any serial console service before using this UART?
  • Is there a recommended UART port/configuration for connecting a CubePilot X25-EVO with Jetson AGX Orin?
Hardware:
  • NVIDIA Jetson AGX Orin 64GB Developer Kit
  • CubePilot X25-EVO
  • ROS 2 Humble + MAVROS
Thank you.
hello pawnavengineer1,
first of all,
let’s try power-off both boards, disconnect all three UART wires, and confirm that Jetson boots normally.
you may refer to pinmux spreadsheets, these are configured to UART1_TX/RX by default.
see-also device tree settings, i.e. uarta: serial@3100000{...}
BTW,
here’s similar discussion thread for your reference, Topic 250884.
Can you please tell me how do i make the flight controller connection with the jetson using uart communication?
Your provided link is not specific.
we’ll need to understand the root cause of booting failure.
please setup serial console to gather the complete UART logs for details.
FYI, Jetson AGX Orin developer kit uses UART3 as debug console.
– Pin-8, UART1_TXD → flight controller RX
– Pin-10, UART1_RXD ← flight controller TX
– Pin-6, GND ↔ flight controller GND
you may double check Running Jetson-IO to configure 40-pin expansion header.
please identify the UART1 with.. $ sudo dmesg | grep -E '3100000|ttyTHS
