Jetson AGX Orin 64Gb won't power up after attempting to switch WiFi module
Hi NVIDIA team,
I am using a Jetson AGX Orin 64Gb Developer Kit, it worked fine without any problem for a long time. However after an attempted to change the WiFi module Intel AX210 (simply remove the current WiFi module and replace it with a new one), the Jetson won’t boot up anymore. I powered the Jetson by USB-C port and the software version was JetPack 6.1, no LED indicated when power plugged in nor pressing the power up button.
Let me know if you need any further information.
Thank you for your support in advanced!
Based on the provided context, I’ll try to provide a comprehensive answer to the question.
The issue described is related to a Jetson AGX Orin 64Gb Developer Kit that stopped booting after attempting to replace the WiFi module with an Intel AX210. The kit was previously working fine, and the software version was JetPack 6.1.
To troubleshoot this issue, let’s consider the following points:
  1. Powering the Jetson: The Jetson is powered through the USB-C port, which is a valid power source. However, it’s essential to ensure that the power supply is sufficient and stable.
  2. LED indicators: The absence of LED indicators when powering on or pressing the power button suggests a possible issue with the power management or boot process.
  3. WiFi module replacement: Replacing the WiFi module might have caused a hardware or software conflict. It’s possible that the new module is not compatible or is not properly seated.
  4. JetPack version: The software version, JetPack 6.1, is relatively recent. However, it’s essential to ensure that the version is compatible with the hardware and that there are no known issues with the WiFi module replacement.
Comparing this issue with other related topics in the provided context, we can find some similarities:
  • ORIN NX unable to use HDMI display: This topic discusses an issue with the HDMI display on a Jetson Orin NX board. Although it’s not directly related to the WiFi module replacement, it highlights the importance of ensuring proper hardware and software compatibility.
  • Unable to read EDID for HDMI on AGX Orin: This topic discusses an issue with reading the EDID (Extended Display Identification Data) on a Jetson AGX Orin board. Although it’s not directly related to the WiFi module replacement, it suggests that there might be issues with the hardware or software configuration.
To resolve the issue, I would recommend the following steps:
  1. Revert to the original WiFi module: Try reverting to the original WiFi module to see if the issue persists. This will help determine if the problem is related to the new module or not.
  2. Check the power management: Ensure that the power supply is sufficient and stable. Try using a different power source or checking the power management settings.
  3. Verify the hardware configuration: Double-check the hardware configuration, including the WiFi module replacement, to ensure that everything is properly seated and connected.
  4. Update the software: If the issue persists, try updating the software to the latest version to ensure that any known issues are resolved.
  5. Contact NVIDIA support: If none of the above steps resolve the issue, it’s recommended to contact NVIDIA support for further assistance.
In summary, the issue with the Jetson AGX Orin 64Gb Developer Kit not booting after replacing the WiFi module might be related to hardware or software compatibility issues. By reverting to the original WiFi module, checking the power management, verifying the hardware configuration, updating the software, and contacting NVIDIA support, you should be able to resolve the issue.
We did switch back the the original module but doesn’t seems to help.
About the power stability, it worked fine for a long time so I think it provided a sufficient power for the device.
Could you try below steps:
  1. switch back normal module
  2. put device in recovery mode
  3. lsusb to check recovery status
  4. flash the device with 36.4.4
Hi @DavidDDD
Thank you for the support. Following you instruction, in the step 2 "Put device in recovery mode”; in order to put it in recovery mode, I did:
”Connect NVIDIA Jetson AGX Orin Developer Kit to the PC with the bundled USB Type-A to Type-C cable.
Make sure you put the Type-C plug of the cable into the USB Type-C port next to 40-pin connector for flashing.
While holding the middle Force Recovery button ( 2 ), insert the USB Type-C power supply plug into the USB Type-C port above the DC jack.” [Ref]
However the power LED still won’t turn on and no dedicate that jetson device connected to my laptop in lsusb
Anything else I can do? Thanks!
No progress on our side. anything more I can try out?
Could you please capture the serial console log during startup?
Additionally, try using a different power supply to help isolate the issue.
If possible, record a video showing that the LED does not turn on when the power supply is connected.
