Yes,
My miniDP still doesn’t work properly. It just shows the NVIDIA badge screen when UEFI is loaded.
I put my module into devkit and I still have the same problem. It only shows the UEFI badge on boot, not the OS interface.
Is other DP monitor also not working on devkit in this setup?
Other DP displays also don’t work on devkit, NVIDIA badges show up at boot, but with the wrong resolution and layout.
What did you change in the software ?
I didn’t change anything in the software.
Then could you flash the whole devkit again with jetpack5.1 BSP and see if the issue is still there or not?
